Clinton County, Michigan | The solar would not be the only power source, but a 12V battery being charged by the solar panel. First check to see how much power the GPS and Radio requires. Then that will tell you how much the solar would need to output. Keep in mind you will have to have a solar panel nearly twice as powerful if the base is going to run all night, and then charge the battery in the day. | |
