| The 37 pin versus the 31 pin on the Rate controller, I was hopeing someone would catch onto that change, that all comes from a oversight on John Deeres part. The wiring harness that Raven has used for a few years is a 37 Pin, but Deere came with the 31 pin, which was pretty much useless because you could not hook directly to the Raven 4400 wiring harness. We I first started working the rate controller, tyring to adapt it too a Summers sprayer, I had to build my own wiring harness to adapt from the 31 pin controller to 37 pin Raven 4400 wiring harness in order to achieve all the full functionality of the rate controller. | |
