Search Forums | Classifieds (43) | Skins | Language
Insight PMM issue
agrarianyuppie
Posted 4/30/2008 22:04 (#368824)
Subject: Insight PMM issue
SE Iowa
Running PMM on Kinze 3000 series. Seed Command also, using the two factory electric clutches. Everything worked great first 5 acres. Then it decided that the left half, rows 1-6, wasn't planting. The pop chart dropped to the 60% mark, no error alarm. When I scan thru the rows individually, it says that
1-6 are planting 0 for population. Yet the bar graph stays blue, just down at 60%. No red alerts and beeping that you get with a real issue. And the entire time, rows 1-6 are planting as normal best as I can tell. My Direct Command switches are both on, with the section indicator lit up properly. When I go into monitor setup and look at the sensors, they are all communicating. I powered everything down, unplugged sensor harness, powered up, plugged back in, etc., etc., with no change. Any ideas?
