Montevideo,Minnesota | Looking at set up a map based prescriptions for next spring planting in 2009 using the JD Greenstar system.What is better use the Brown Box display or the GS2 2600 display for this? Will also be using JD autosteer in the tractor. I have JD Seed Star on the planter also. So instead of having two display in the cab it would be better to just to have one the GS2 2600.
Is the map based prescription hard to setup ? ( I will be using APEX 2.0)
Thanks
Edited by Golden Farms 4/14/2008 22:03
