Posted 3/14/2008 19:37 (#334056 - in reply to #333960) Subject: RE: fluid dynamics
Mc Crory, AR.
I believe the amps will go up at first until the pump reaches the max amount of pressure it is designed to pump. Then at that time it will start going down in proportion to the flow of water. The reason why I say this, I have taken a 2" well and stop the flow completely the amps went to almost nothing.
