| I have a late 2003 STX 325 with the 16 speed powershift. It has developed a bit of a glitch wheres ometimes when I put the transmission in forward, the dash starts beeping at me with the box flashing around the neutral indicator. It will drop into reverse just fine but does not seem to want to go forward. I have tried starting it in different gears and shuttling the transmission from reverse to forward, but it doesn't seem to make much difference. Other times it seems to work all right with the transmission working as designed. Dealer thinks it is a wiring problem.
Just wondering if anyone else has had this problem and where I should be looking in the wiring loom to look for any loose / bare wires that may be causing this problem.
Thanks in advance
Nick
