Posted 2/24/2008 01:53 (#317854 - in reply to #317692) Subject: RE: How to loosen large ALUMINUM hub from shaft?
NW Washington
JMHO, but I think you are SOL. Aluminum has a nasty habit of galling or basically bonding to steel in a tight fix and it will only come apart in pieces. You have to goop the parts up well with never-seize before assembly if you ever hope to get them apart.
