Posted 1/27/2008 22:18 (#294772 - in reply to #294646) Subject: RE: RTK costs?
Arlington, KY
I run JD RTK and like it very well. I like the RTK extend the JD has. If you loose signal from the base you can run for 15m with full accuracy. I run 7 RTK systems with 3 base stations. We have been using this for 4 years with no problems. As far as cost I think RTK cost about $4000 (per unit) over a SF2 system.
