Posted 1/14/2008 00:13 (#282757 - in reply to #282589) Subject: Re: Fasteners for hedge posts
NC Kansas
depending on the size of your post we have used 1/4 to 3/8 rebar or rod, bend small j in one end drill hole in post insert rod through post bend down on opposite side making sure bend is tight around pannel. if you want can drill second shallow hole so short end of the j bend is seated into post. a lot of work but once its done it stays.
