| Convergence time depends mostly on the number of satellites you receive. The more satellites you receive, the shorter convergence time is. I have done some testings last year with Trimble 252 receivers. I have seen, that HP convergence is a little bit faster, but this was not a huge or significant difference. About 2-3 minutes. What I also observed, if you use autoseed function and you have moved the vehicle it takes much longer time to converge. I use instead a very high convergence distance and turn autoseed off. | |
