Search Forums | Classifieds (130) | Skins | Language
homemade jug rinse (from below)
Chad H
Posted 6/16/2006 00:51 (#19801 - in reply to #19764)
Subject: Re: homemade jug rinse (from below)
NE SD
Ray, don't you have an eductor on your 4700? We had one on the 4700, but the one on the 4710 is nicer. Just push down on the jug and fresh water rinses it out. We like the eductor.........good place to put in ammonium sulfate etc. We've still got to get on the trailer to load roundup in the cone though. If I could come up with a decent way of quickly and ACCURATELY metering it out of a 200 gallon cone I'd rather do that as well.........the only thing that slows down our fills is waiting for those slow pumps to pump it into the cone on the truck.
Are there any good accurate and affordable in-line meters a guy could use in junction with a venturi? What's a venturi cost? We just use suction now.........and have to limit water flow through the line because when the big tank is full with the 3" plumbing it will start to fill the cone.
