Central To Everything and Close to Nothing | What version of Apex are you using? If you are using 1.5, I would suggest you order a copy of the 2.0 beta from Stellar Support as I believe the image correction tool has been improved.
I'm certainly not an expert on this but simply put, your aerial images were probably geo referenced after they were taken and the scale might not be exactly as adervtised. Until you attempt to do what you are doing, you would never know the difference. Since your driven boundaries are going to be very accurate, they will identify the discrepancies of your images thus why most ag GIS programs have an image corrector tool. |
