Posted 12/2/2011 22:54 (#2081690 - in reply to #2081523) Subject: Re: Concrete Feed Troughs
WY, OK
We use some old concrete water tanks that are 8-10' to feed the bulls. Only issue is the weight and the chance of them breaking in half when you move them. Make sure and put them on some wood or something to keep them off the ground a little bit so you can get some forks under them when you need to move them.
