| Have an EZ Guide 500 and EZ Steer T2 set up on an STX 450 Quadtrac with Omnistar HP, but can't get it to work very well. It wags like a dog while trying to find line, then justs drifts about after that. I'm using the articulated 4wd default settings. The reciever is on a bracket just in front of the cab, nearly over the front axle - would it be better either behind or well in front of the front axle ? Any suggestions would be gratefully recieved ! | |
