Central To Everything and Close to Nothing | Chuck, I'm in central Alberta. Same issues with wheat here as well as far as variability goes but probably not quite to the extremes that you guys get. I have worked with the Insight and GS2 and both I believe have the ability to do some layering on the go. To your comments about compatibility....... ISOBUS can't get here fast enough! Thanks for the info, I would interested in hearing about your plot results when the chaff settles. |
