Crawford, MS 39743 Uniontown OH 44685 | aren't you growing alfalfa down here in the deep south? Tell me what you did to get it established, what did you plant, pop, anything to help me get it going. I want to try some this fall and any help would be apperciated. It's coming out of three year old orchard grass. Well drained ground, ph 7.6. Orchard grass pretty much petered out this year so time for a new experiment. Planning on killing off existing vegetation with rup, should i fully work up the ground or just do a heavy scratch so i don't get seeds to deep. This is just a little field kind of a pain only two acres so i use it as my experiment field. Thanks Andrew |
