Posted 7/6/2007 21:22 (#171205 - in reply to #170532) Subject: RE: raven 4600 rate controller
Lloydminster Saskatchewan
Thahk you Ted. I did the self test, like you said, and found out that boom switch #3 was reading 0, so I traced back on the wiring harness and
had a broken wire to boom #3. I put it together and now everything seems to work. Thank You !!!!!
