“These are the times that try men's souls.” | Nice tool. Lynn, what I do is load bale on forks then get off tractor cut net low on left hand side. Flip it over bale, then walk up to back of tractor, push hyd. lever to start loading bale ( I've use a 40 series JD tractor as well ). Then walk back to bale as it is lifting into processor, grab net and hold on to it, pulling it as it falls into processor. I never have to clean rotor off that way. |
