Posted 3/25/2011 21:58 (#1690334 - in reply to #1687033) Subject: Re: light bulbs in hog building
North Central Iowa
Try the lower watt CFL bulbs, i think they are 23 watt. The higher watt in the jar enclosures will build up heat and reduce lifespan. Make sure your light fixtures seals are good and not letting in moisture and gas.
