SC, MN. | I'll second the FLUID FILM suggestion. Stop @ your local John Deere dealer a get a can. Hand down the best remidy for ring worm that I've found. I had a spot on my shoulder a few months ago so I decided what the heck & put some on for 3-4 days & It did go away. I can't tell you how long it took to disapear cause it quit itching and I forgot about it.
Fluid Film is a lubricant / penatrating oil / rust protectant, the key ingrediant is LANOLIN oil from wool. Once you smell the stuff it does have a wool smell to it. Google Fluid Film & you will be amazed @ the things you can use it for. It has a interesting story on its invention (WWII). | |
