Posted 1/5/2011 10:43 (#1528161 - in reply to #1527888) Subject: Re: SYRUP FROM ENTHANOL PLANT..??????
LeRoy IL
Yes its a good feed. The stuff I am useing is 60% moisture. On a dry basis its 18% protien net energy is around 1.1 and sulfur is .82. Syrup also has alot of phosphous. Here it's $3/ton. When its cold it's stiff do you keep your heated and how much will you feed per day.
