Central Kansas | With the wet distillers from ethanol plants you still need to worry about the sulfur amount. You should always test your water to see what the sulfur level is because if it is elevated very much than you could be setting yourself up for a disaster. It amounts to how high the sulfur in the water at the ethanol plant is when they distill the grain.
Edited by cattlefeeder 10/12/2010 20:02
