North Dakota | RTK, regardless of brand, is for 10km/6miles. The reason for this is it has to have the same GPS satellites in view and be that close to calculate the error of the signal, beyond the 6 mile limit the error grows exponentially (at 6m you have <1" accuracy, at 12m you have >4" accuracy) in theory.
The repeater is only to bounce the base station signal around an obstruction, your implement should still be within that 6 mile radius. | |
