If VTG is also turned on will this cause a problem for the Greenstar? Can the Greenstar be set up to handle higher data speeds such as a higher baud rate and 5 Hz from a brand X reciever? The reason I ask is if we use a Y cable to supply gps to both the GS and AL Insight from a Outback SII it would be advantagous if we could set the Outback output to 5 Hz and baud rate to 19,200 for the benefit of the Insight.
There is nothing in the operators manual as far as I can find telling anything avout using a non-Starfire reciever although I know lots of people have done it for yield monitoring. Thanks. John
Edited by John Burns 3/4/2007 17:07
