Casey IL. ( I -70 ) then south on rt.49 | Try sewer tape should till you where the plug is and maybe able to bump it enough to unplug it. Most likely it will be closer to the top so be real carefully wading or being around the pipe [on top ] if it comes loss, will have a lot of suction could get you bad. I have worked on this type of problem and it can be danger est so be car full. |
