Posted 1/27/2010 09:42 (#1043857 - in reply to #1043553) Subject: RE: DO YOU HAVE MAGIC JACK?
Macon, IL
It works-but unless your connection is really fast the calls will break up now and then. You can use the internet at the same time but if you start surfing or downloading it gets much worse.
If you have a fax on that line don't even think about it.
