Half windows--------- how can I change...........
Chad H
Posted 4/18/2006 09:37 (#6092 - in reply to #6087)
Subject: Re: Half windows--------- how can I change...........
NE SD
Jake,
Ed taught me this trick, so it is a gooder. Instead of using the max window size button(that square one up in the corner by the "x") to expand the window out all the way, make the window full size manually, and then close out of it. Apparently, some webpages, links, etc. are set up so that they call for a partial sized page default. If you do this, next time you open the explorer, you should see a full window.
