Posted 4/19/2024 23:29 (#10713040) Subject: JD 1770nt hyd hose hook ups to Jd 8570
sw MN
The planter has 2 hyd drives 2 vac moters ccs 11 hoses
The tractor has 4 scv power beyond pressure case drain
I need to combine 2 returns. Can I combine the 2 hyd drive returns or the vac returns? Should the returns from the hyd drives and the scv's be hook to the side plugs on the scv's to reduce heating? What is best hooked to the power beyond? tia
