Posted 4/17/2024 16:51 (#10710397 - in reply to #10710365) Subject: RE: Submersible well, Spool Type Pitless, get pressure switch out of the way?
nw ohio
I imagine you have to pull the pump to get to the press. switch. I only once ever ran into a setup that was like that. We dug the well and installed a 4"X6" offset Fernco to do it correctly. Still had to pull the pump up to service the switch.
