Posted 4/17/2024 07:31 (#10709717 - in reply to #10709526) Subject: RE: Case IH seed meter - little corrosion
It's corroded in that corner because dust builds up and draws moisture or gets wet from rain. It builds up because there is no action or flow in the corner, the corn just sits there. I don't think it is a problem that needs anything, you have already done a good job of cleaning.
