Jeffersonville, OH | RA1 - 4/28/2024 21:17
It should be fine for him, he doesn't have big equipment and doesn't put a lot of hours on it in a year. I've never pulled the engine on a Allis before, looks like I'll have to support it and pull front axle off, then frame rails, then remove the engine from the trans bellhousing. I've mostly worked on Deeres, just split them roll the front away and slide the engine out of the rails.
Yep, you have it right
Chris |
