| when you use headlands, you have outer and inner boundary... if you turn on inner boundary, it will shut off the sections when you cross the headland line, and you use that when you use virtual headland, and you plant infill first, and headlands at the end... when you turn on the outer boundary, it will do what you want...
i did not find a way to square corners on headlands, you can do it on FMX turning on Headland2 option, but not in PIQ....
there is Trimble AG Software, named Farmer Core, where you can edit boundaries you have already done... and on the newest wersion of PIQ you can generate a new headland from boundary you have fixed on Ag Software... | |
