zkeele - 3/27/2024 21:08 What do you think could cause the problem I'm having? Bad nav? Lines are straight on light bar mode. Bad Nav or Autosense. I know the cables have been an issue in the past but per my post below, I had 2 of my 3 nav's go bad last year. Had the same symptom where it would be pointing in the wrong heading and would never stay online. Ag express fixed them both. I believe bench fee is $85 and that with the shipping was cheaper than plugging and playing to try and track down the issue. Repairs Needed: * Repair Power Supply Circuit to stabilize voltages. * Repair CAN Bus Circuit to improve CAN signal. * Repair IMU Circuit to improve gyros performance. * Repair Filter Circuit to reduce noise. * Install Updates to Main Board
Repairs Needed: * Repair CAN Bus Circuit to improve CAN signal. * Install Updates to Main Board |
