| jd4930 - 3/28/2024 06:55 They use direct injection
I imagine it may exist but I have not seen any of these systems that use direct injection. I would think that would be impossible because you have a split second between the time the need to apply is identified and the time application occurs. I would not think direct injection could get mixed into the liquid stream in that amount of time.
The systems I have seen (See and Spray as well as GreenEye) have two tanks and and two different product mixes and two different pumps and two different nozzles running different products. One is spraying all the time for residuals and the other is spraying only when it sees weeds. |
