Search Forums | Classifieds (29) | Skins | Language
Drainage culvert for small area
AR Plowboy
Posted 3/14/2024 23:09 (#10665484)
Subject: Drainage culvert for small area
East Central Arkansas
So less than 1/4 ac in yard where the gravel drive holds water. Have just had a shallow drain cut across drive but need better drainage because of shed going in the area. Building that area up isn't a option. I think a 6 inch pipe will handle the water but wonder if one should use a 8 inch pipe to prevent plugging. Will be at least 25 foot of pip underground pipe. Have another 15 to 20 foot could be drain tile but don't know if I can get larger than 4 inch around here. I have some 5 x 7 toolbar I might consider using. I think probably 3/16 inch.
