Posted 3/6/2024 19:45 (#10654658 - in reply to #10654330) Subject: RE: ceiling fans
I've had luck switching the blades around. Switch two side by side and then switch one of them with the next, etc. It worked for me, sometimes you get the bad blades opposite each other. Now if you only have one heavier or lighter blade it doesn't work, but it's a place to start.
