Posted 3/2/2024 20:29 (#10648854 - in reply to #10648738) Subject: RE: Elevator contracts WRONG time to use
Sioux Falls, SD
Premiums on the accumulators will decrease as you will lose the time value. Not saying now is the time for accumulators, but if the markets are at the same level as today or slightly higher, the premium for the accumulators will be lower 3 months from now. Right now seeing 45 cents or so with a 4.25 type knock out.
