NE Indiana | Though not recommended for accuracy reasons I believe that you would be to use it to install tile with the old gradient signal. However once you upgrade to the Ag Leader Intellislope it will not work. Its been a while but I thought that the old gradient could use RTX (which I imagine is the same messages as SF-RTK) however once Ag Leader bought SoilMax and started using their display for the Intellislope they tightened the accuracy tolerances and stopped the use of RTX signal as an accepted RTK source. | |
