Posted 1/10/2024 08:42 (#10566252 - in reply to #10565511) Subject: RE: Great Plains 2000 Drill monitoring options
North Central Ohio
I've done a couple of Great Plains with AgLeader. Worked with agexpress to build a harness to do every other row (because agleader is limited to 36 with a STMM module). You have to trick the config so it works correctly - double the row spacing and make the gain factor as 2 (or a little higher than 2). It's not a perfect situation, but works pretty good.
