Peru, IL | I'm renting a dry applicator that has a Raven 660 controller. For some reason, the bottom row of buttons are inactive. I had a Raven 440 on the shelf, so I put it in the cab. I input all the same setup values that the 660 had. I'm trying to apply 300 lbs./acre. Two bad things happened. The boom control switch doesn't stop the belt in the spreader when the switch is turned off. And secondly, the monitor consistently told me I was underapplying, around 25% of target. In reality, I applied 548 lbs/acre, 83% above target. I'm pretty sure I was accurately counting speed and acres. Maybe I need to use factoring on the 440?
Ideas?
