Search Forums | Classifieds (24) | Skins | Language
point to point wi-fi between buildings.
guessrow
Posted 10/7/2023 15:33 (#10431457 - in reply to #10415975)
Subject: Can you bury ethernet cable?
Le Sueur VIA St.Thomas
Hello- Would your situation allow you to bury ethernet cable between the 2 buildings? If so, you could hook the one end up to your existing system and run it to the new building. You can install a wireless router for that area or whatever you want.
good luck -jim
