Posted 5/27/2023 06:14 (#10245326 - in reply to #10245322) Subject: RE: You guys with clean sweep….
Minnesota
I had trouble the first year. Just needed to re-route some lines and lots of zip ties. Only one problem this spring in 1500 acres. One of the quick connectors gave up. The idea of running the lines under the cylinders sounds good.
