W.C. Mo. | Make darn sure you have the correct wiring harness on the 9670 if you go with the jd head. I thought mine was correct with the heavier feeder house and cylinders. I discovered when I fired it up that the draper required more height sensors the my 9670 was wired for. A extra $8000 got it running.
Maintenance and attention--look over belts closely. Also those dam hyd hoses going to each of the cutterbar cylinders | |
