| If you back on the lower left of the run screen, then go to calibration tile, then go to NAV tab. You can see the wheel angle values by selecting steering sensor, you can cancel out and it won't mess up any cal values already. main thing to look at is if you have the tractor driving as straight as humanly possible the voltage value should be pretty close to 2.72 as possible. then you can also slowly sweep left to right or vise versa to see if the sensor has a bad spot in it. hope this helps you some. | |
