Northern Ohio Grain | tedbear - 5/19/2022 08:09
Using a N.C. Deere button switch will connect the terminals when the planting unit is down and the button is NOT depressed. I forget if this would be the correct or opposite action. I don't remember if the action can be reversed with a menu setting or not.
My thought was to use a normally closed switch like the deere button switch, should connect the two wires when planter units are in the ground (raised). Wont have any voltage in the loop. I may try it and see what happens. |
