Posted 6/11/2009 23:35 (#742041 - in reply to #741679) Subject: Re: Slow hydraulics on JD 4430
Lapel, In
Cut the filter open and look for black bits of brake lining. If you find some, you have a mess on your hands. Could be every hydraulic component will need going through. I assume the filter has been changed and suction screen has been pulled out and checked for debris. Find any brake lining in the screen ?
