Search Forums | Classifieds (94) | Skins | Language
7140 Magnum and 1770 vac: Will it or won't it?
pugsley
Posted 6/10/2009 09:52 (#739536 - in reply to #738806)
Subject: RE: 7140 Magnum and 1770 vac: Will it or won't it?
sw mn
If you are going to run a 12 row 1770 with 1 vac fan you will probobly be alright but most 16 rows have 2 vac fans and it will run it fin but raising on the end rows might be slower than you might like Ihave a neighbor that runs that setup and he plumbed his markers in on a separate remote so he could raise the markers before he raised the planter on the ends and gets by fine but he stops on the end and raises the planter
