| I had Schabens help me last year with a similar situation. We did a small
hydraulic hypro pump, an electrice ball valve for on and off flow to the unit,
a pressure gauge, and then a manifold to tee off to each row. The return line
valve is how we adjust the pressure. For suspension type ferts, it made it easy
to keep the product recirculating.
It is a speed and pressure set up so your speed needs to stay as constant as possible
Works great and was simple.
Duane
