Chipman , Alberta | How do you get the back cover off to change the pto seals on both shafts? Comes back about a 1/4" then stops? What's the next step? Also the tractor data center will only let then tractor run when in bypass mode.When you turn the key on all systems indicate operational, then start the tractor there are no red warning lights to tell what is causing shut off of engine...? What do I check next? TIA | |
