Huntley Montana | <p>I've got 33x12.50-15s on my 220. Got a set of tractor tread 21.5x16.1s on MAX offset rims for it if needed, but I haven't bought the spacers I need yet. Had a set made, but I need longer bolts to use them. Saw a set the other day that looked like they would be the "ticket" for $285 for 4. I'm thinking with the 21.5s I need to run with a 1/2 tank so as not to break axels . But if it's that wet I need them, maybe I only want a 1/2 tank. I got the rims from Hewitts in Monroe Ia, they have the max offset, but lack about 1 1/2-2" from clearing the sides, so I need spacers also.</p><p> </p><p> By the way it's a 6 bolt imp rim, same pattern. So IF you have a wide set of imp rims you can go wider.</p>
Edited by Badger 5/25/2009 21:58
